PIX 501 to Block Websites
Jun 16, 2007 2 Replies
Hi, new here so please be kind if i am not doing this right the first time. we have a Pix501 and I need to figure out (if it is even possible) to setup the PIX to block certain website. If so, how is that done? The PIX firewall version 6.1(2) The PIX device manager version 1.1(2)
Thank, Steve
With that software version, the only way to do it would be to add an (expensive) Websense server. Somwehre around 6.3 they added the ability to use N2H2 servers as an alternate -- still commercial, though.
This is presuming that you wish to block by site -name-, not by IP address. You can block by IP address without difficulty, but it does require that you keep up with IP changes to do much good.
A generally more productive way to filter by site -name- is to install an internal squid server, and block outgoing web access except from the squid server, and then set everyone up to use the squid server as their proxy. A couple of people recently mentioned SafeSquid as being suitable for this purpose; I've never looked at that myself.
If you are the original owners of that 501, you should get it upgraded to the last 6.1(*) version to fix a bunch of security problems. The upgrade would be free. You were supposed to ask for the upgrade from your VAR; if your VAR isn't still around or is one of those no-frill VARs, you would ask for the upgrade from Cisco. You would search Cisco's web site for PIX Security Advisories, look through the older ones, find one that authorized the upgrade, and call up Cisco and cite the document ID, and Cisco would make the upgrade available even if you had no support contract at all. But I don't know if Cisco still has copies of 6.1(*) available for download; you might be too late to get your upgrade from Cisco. [But if you are the original owner and you -somehow- managed to get a hold of the 6.1(*) upgrade then there wouldn't be any problem: you would be entitled to it in that case, even if it didn't arrive straight from Cisco.]
If you aren't the original owners of that 501... Sorry, no security upgrade entitlement in that case.
Note: the security upgrade won't improve your ability to filter web sites.
Or you can make a static entry for that website on your internal DNS.
