PIX 501 Routing vs. NAT
May 07, 2009 3 Replies
Jump to replies (3)
My wan interface is on x.x.x.254/29 network. Can I set up a route, rather than nat, to x.x.x.253?
If yes, how?
Thanks in advance
what are you trying to accomplish? You can assign as many IP address to the wan interface, however without NAT, you can not publish any services behind the firewall unless your machines reside on the same subnet as the outside interface, which means you are using no nat rules.
Thanks for your help.
I would like to bypass firewall for this >> My wan interface is on x.x.x.254/29 network. Can I set up a route,
Correct in that instance you will be using 2 external IP address that are routeable on the internet. You will assign one to the PIX interface you are working with and the other to the machine in questions. Please note if you are not using NAT for this DMZ zone, you can not use NAT in the future for this zone.
You would be better suited if you use NAT a create a static translation to the machine you are talking about, once you created the NAT translation you then would create ACL rules to allow traffic to the machine.
static (DMZ,outside) OUTSIDE.IP MACHINE.IP netmask 255.255.255.255
access-list outside_access_in extended permit tcp any host OUTSIDE.IP eq https
For example, the 2 lines above will allow HTTPS traffic to a machine located in the DMZ.
