Ping a untrust interface at cisco asa 5505
Aug 31, 2007 1 Replies
Hi all,
what must i set in the ASDM when i will ping a outside interface?
I have set properties->device adminstation->ICMP Rules. I have add the a rule that any ICMP Typs, any address on the outgoing interface are permited... But i cant ping the ip address of the outside interface.
What make i wrong? It?s my first time with a Cisco ASA.
Can my help please someone. Thanks.
Bye, Michael
You can't. With either the Pix or ASA you can only ping the interface closest to you. There is only 1 exception to that and it is with VPN tunnels with the "management-access" command, it allows you to manage the firewall via a VPN session.
