Outbound PPTP PIX Problems
Feb 06, 2008 0 Replies
trying to get outbound PPTP working through our PIX, i've added in ISAKMP NAT TRAVERSAL 20 , thinking this would resolve it but no luck! anyone have any ideas? i've pasted sanitized config below:
Regards
Paul
interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol pptp 1723 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list out-acl permit tcp any any eq ssh access-list out-acl permit icmp any any access-list out-acl permit tcp any host xx.xx.xx.35 eq pptp access-list out-acl permit gre any host xx.xx.xx.35 access-list out-acl permit ip yy.yy.14.0 255.255.255.0 yy.yy.9.0
255.255.255.0 access-list out-acl permit tcp any any eq pptp access-list out-acl permit gre any any access-list 100 permit ip yy.yy.14.0 255.255.255.0 yy.yy.9.0
255.255.255.0 access-list 100 permit ip yy.yy.14.0 255.255.255.0 yy.yy.10.0
255.255.254.0 access-list 110 permit ip yy.yy.14.0 255.255.255.0 yy.yy.10.0
255.255.254.0 access-list 120 permit ip yy.yy.14.0 255.255.255.0 yy.yy.9.0
255.255.255.0 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside xx.xx.xx.34 255.255.255.248 ip address inside yy.yy.14.254 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 100 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp xx.xx.xx.35 pptp yy.yy.14.1 pptp netmask
255.255.255.255 0 0 static (inside,outside) tcp xx.xx.xx.35 3389 yy.yy.14.1 3389 netmask
255.255.255.255 0 0 static (inside,outside) xx.xx.xx.35 yy.yy.14.1 netmask 255.255.255.255
0 0 access-group out-acl in interface outside route outside 0.0.0.0 0.0.0.0 xx.xx.xx.33 1 http server enable http yy.yy.14.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection tcpmss 1300 sysopt connection permit-ipsec crypto ipsec transform-set atosset esp-3des esp-sha-hmac crypto dynamic-map dynmap 40 set transform-set atosset crypto map newmap 10 ipsec-isakmp crypto map newmap 10 match address 110 crypto map newmap 10 set peer xx.xx.xx.227 crypto map newmap 10 set transform-set atosset crypto map newmap 20 ipsec-isakmp crypto map newmap 20 match address 120 crypto map newmap 20 set peer xx.xx.xx.114 crypto map newmap 20 set transform-set atosset crypto map newmap interface outside isakmp enable outside isakmp key ******** address xx.xx.xx227 netmask 255.255.255.255 no- xauth no-con fig-mode isakmp key ******** address xx.xx.xx.114 netmask 255.255.255.255 no- xauth no- config-mode isakmp identity address isakmp nat-traversal 20 isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash sha isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet 0.0.0.0 0.0.0.0 inside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh timeout 5 console timeout 0 terminal width 80
