No LAN connectivity on Pix 515E
Apr 28, 2007 5 Replies
Jump to replies (5)
Having a problem with Pix515E that I just configured where I can't ping nodes on LAN from the pix and vice versa. Pix has an outside interface which is plugged in, the additional interface is not plugged in and not being used, and there is a built in 4 port switch on the unit that I have two workstations plugged into with static ip addresses on the internal network (10.10.10.x). Workstations get the link light and signal but request times out when pinging the pix(and can't ping workstations from pix either). Although I am able to ping out to the Internet from the pix I cannot communicate with the internal network. I think it may be related to the "interface ethernet1 "inside" is up, line protocol is down" when I do a show int. DataLink layer problem? Does anyone have any ideas about how to fix this?? I pasted a show int command followed by my pix config. Thank you
Ladanian
sho int
interface ethernet0 "outside" is up, line protocol is up Hardware is i82559 ethernet, address is 0012.0166.40d8 IP address 167.206.150.180, subnet mask 255.255.255.128 MTU 1500 bytes, BW 100000 Kbit full duplex 17538 packets input, 1177917 bytes, 0 no buffer Received 17521 broadcasts, 0 runts, 0 giants 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 9 packets output, 582 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collisions, 0 deferred 0 lost carrier, 0 no carrier input queue (curr/max blocks): hardware (128/128) software (0/5) output queue (curr/max blocks): hardware (0/1) software (0/1) interface ethernet1 "inside" is up, line protocol is down Hardware is i82559 ethernet, address is 0012.0166.40d9 IP address 10.10.10.1, subnet mask 255.255.255.0 MTU 1500 bytes, BW 100000 Kbit full duplex 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 46 packets output, 2760 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collisions, 0 deferred 0 lost carrier, 0 no carrier input queue (curr/max blocks): hardware (128/128) software (0/0) output queue (curr/max blocks): hardware (0/2) software (0/1) interface ethernet2 "intf2" is up, line protocol is up Hardware is i82559 ethernet, address is 000d.88ef.282c IP address 172.16.23.1, subnet mask 255.255.255.0 MTU 1500 bytes, BW 100000 Kbit full duplex 446 packets input, 29308 bytes, 0 no buffer Received 446 broadcasts, 0 runts, 0 giants 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 1 packets output, 60 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collisions, 0 deferred 0 lost carrier, 0 no carrier input queue (curr/max blocks): hardware (128/128) software (0/1) output queue (curr/max blocks): hardware (0/1) software (0/1)
Pix config:
--------------------------------------------------------------------------------------------- PIX Version 6.3(3)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password RGjV8czquBx/fqoO encrypted
passwd RGjV8czquBx/fqoO encrypted
hostname mypix
domain-name mydom.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 1500
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060 fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_out permit icmp any any
access-list acl_out permit gre any any
access-list acl_out permit esp any any
access-list acl_out permit ah any any
access-list acl_out permit tcp any host 167.206.150.181 eq smtp
access-list acl_out permit tcp any host 167.206.150.181 eq www
access-list acl_out permit tcp any host 167.206.150.181 eq https
access-list acl_out permit udp any any eq isakmp
access-list acl_out permit icmp any any echo-reply
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 167.206.150.180 255.255.255.128
ip address inside 10.10.10.1 255.255.255.0
ip address intf2 172.16.23.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 167.206.150.181 10.10.10.11 netmask
255.255.255.255 0 0
access-group acl_out in interface outside
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 167.206.150.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
telnet 10.10.10.0 255.255.255.0 inside
telnet timeout 5
console timeout 0
terminal width 80
The PIX 515E does *not* have a 4-port switch: every connection on the PIX 515E is a different interface.
The PIX 501 is the only PIX model with a 4-port switch, but it does not have "ethernet2", so you can't be using a PIX 501.
Do you hve internal interface plugged in same as outside interface.. ? If not it will not be pinged from any interface..
----=AD----------------------------
----=AD------- Hide quoted text -
My external interface Ethernet0 is plugged in to the Router. The next port over is Ethernet1 and is not plugged in. Then there are 4 ports together that look like a switch at the other end. I have my servers plugged into two of those ports. which port is intf2?? strange because servers get a signal and link but no communication beyond that... _________________________________________ OOOO O ethernet1 Oethernet0 _________________________________________
First of all, your Pix is only recognizing 3 interfaces based on your config above. Means only one thing, you have a 515R, it only supports 3 interfaces.
As you have it layed out above: Eth6, Eth5, Eth4, Eth3........Eth1......Eth0
You do not see 6,5 and 4 in the config because you are not licensed for those interface. They are physical interfaces, not switch ports as you have already been told by another member.
------=AD=AD----------------------------
------=AD=AD-------
I didn't realize interfaces needed to be licensed. Thanks I will look into that.
