Newbie needs the most basic of help with a PIX 515
Sep 01, 2005 5 Replies
Most relevant reply
Walter Roberson
:PIX Version 7.0(1) :access-list ping_acl permit icmp any any :access-group ping_acl in interface inside :access-group ping_acl in interface dmz :access-group ping_acl in interface outside I haven't looked at the details of your configuration, but the above popped out at me.…
Hello,
I have been tasked with configuring a PIX 515, but my Cisco skills aren't up to the challenge. I have set up and maintained some networks using Linux gateways with iptables, so I do know the basic concepts involved. In order to learn how to make things happen on the PIX, I've set up a test environment consisting of three machines, each on one interface on the PIX. My initial goal is to be able to ping across to the network to each machine. Once I have connectivity, I can start writing my access-list rules.
Unfortunately, I am unable to ping across the PIX to any of the other networks. My configuration is:
PIX Version 7.0(1) names ! interface Ethernet0 nameif outside security-level 0 ip address 10.0.100.190 255.255.255.0 ! interface Ethernet1 nameif inside security-level 100 ip address 10.0.0.1 255.255.255.0 ! interface Ethernet2 nameif dmz security-level 20 ip address 10.0.5.1 255.255.255.0 ! interface Ethernet3 shutdown no nameif no security-level no ip address ! interface Ethernet4 shutdown no nameif no security-level no ip address ! interface Ethernet5 shutdown no nameif no security-level no ip address ! enable password v3eNd/VU2QcDQYO6 encrypted passwd 1eLX4kzXqzXs6wsU encrypted hostname pixfirewall ftp mode passive no pager mtu inside 1500 mtu outside 1500 no failover monitor-interface inside monitor-interface outside asdm image flash:/asdm no asdm history enable arp timeout 14400 nat (inside) 1 0.0.0.0 0.0.0.0 nat (dmz) 1 10.0.5.0 255.255.255.0 0 static (dmz,outside) 10.0.100.10 10.0.5.5 netmask 255.255.255.255 0 0
access-group ping_acl in interface inside access-group ping_acl in interface dmz access-group ping_acl in interface outside
timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute no snmp-server location no snmp-server contact snmp-server enable traps snmp telnet 10.0.0.200 255.255.255.255 inside telnet timeout 5 ssh timeout 5 console timeout 0 : end
Which obviously is missing something. The first thing I'd like to accomplish is to be able to ping 10.0.100.190 from machine 10.0.5.5 on the DMZ interface. Second would be to be able to ping 10.0.100.10 and have that hit 10.0.5.5. Once that is working, don't think it would be to hard to allow ssh logins to 10.0.100.10 (10.0.5.5).
Thanks for any help!
Tad
In article , wrote: :PIX Version 7.0(1)
Effectively you cannot reuse access-lists on the PIX: the PIX manipulates them internally for purposes related to the Adaptive Security Algorithm. And some other cases that you wouldn't think could cause a conflict have had bug reports against problems with shared ACLs.
So, on the PIX, if you need the same ACL functionality in more than one context, you should duplicate the ACL contents. If the ACL is non-trivial, using object-group can help reduce the clutter a fair bit.
you need the global command that would tell the pix what the internal addresses should be translated into. It would be something like this:
global (outside) global (outside) 1 209.64.3.129-209.64.3.253 netmask
255.255.255.128
where the ip addresses in the line above are the range of public addresses available to you.
If you dont have enough public addresses use pat by defining only one global address such as
Good Luck.
snipped-for-privacy@tadland.net wrote:
I've incorporated both of these changes, and now I have something like this in the relevant parts of the configuration:
global (outside) 1 10.0.100.1-10.0.100.255 netmask 255.255.255.0
access-list ping_inside_acl permit icmp any any access-list ping_dmz_acl permit icmp any any access-list ping_outside_acl permit icmp any any access-list ssh_dmz_acl permit tcp any host 10.0.100.10 eq 22
access-group ping_inside_acl in interface inside access-group ping_dmz_acl in interface dmz access-group ping_outside_acl in interface outside access-group ssh_dmz_acl in interface outside
I still cannot get data across the interfaces into a different zone. I can ping 10.0.100.10 from a machine on the outside of the PIX, but the ttl is 64 so I'm feeling like the traffic isn't actually getting to the machine that is supposed to be NATed to 10.0.100.10 (10.0.5.5).
Any other suggestions?
Thanks, Tad
I'm not sure that my changes are progress. I now get the following errors loading the configuration file:
!Error: 10.0.100.1-10.0.100.255 overlaps with outside interface address Duplicate NAT entry Duplicate NAT entry ERROR: mapped-address conflict with existing static dmz:10.0.5.5 to outside:10.0.100.10 netmask 255.255.255.255 Config Error -- static (dmz,outside) 10.0.100.10 10.0.5.5 netmask
255.255.255.255 0 0 WARNING: found duplicate element WARNING: found duplicate element WARNING: found duplicate element ERROR: entry for address/mask = 10.0.0.200/255.255.255.255 exists
The first error is just me needing to change the range of the global statement. I don't understand the "Duplicate NAT entry" messages and the "found duplicate element" errors on the access-lists seems to be contrary to the first sugesstion above.
Tad
In article , wrote: :access-group ping_outside_acl in interface outside :access-group ssh_dmz_acl in interface outside
This doesn't address your original problem, but: you can only have one access-group per interface (per direction in 7.0).
