New FR Circuit Wont Stat Up
Oct 15, 2007 4 Replies
Jump to replies (4)
We just added a new FR circuit to our network. No alarms on smart jack or Adtran CSU/DSU. However, I can't get the circuit up. When I reload the router, I get connectivity for about 30 seconds after the reload, then S1 goes to up/down. DTE LMI is also down. I replaced the v.35 cable going from the router to the CSU, but still no luck.
Have tried setting lmi-type to both Cisco and auto. It autodetects cisco.
I can try to do a debug, but not sure what to look for. Any suggestions appreciated.
Are you sure that the carrier has activated at their end ?
Cisco frame-relay troubleshooting doc:
try "debug frame-relay lmi" to see if you get any output
see Cisco frame-relay troubleshooting doc:
Turns out ISP had set the protocol to "disabled." I guess that's the "turn up" part of "test and turn up."
If the circuit is now up, it might be a good idea for you to capture some of the debug outputs spo you know what they looks like when circuit is operating properly
