Need Help Setting Up Failover & Redundancy
Apr 10, 2006 1 Replies
I'm pretty new at setting up Cisco Routers. I need your help here.
We have 2 T1s going to the same location. They are supposed to run concurrently, and be backups for each other. Right now I believe they are setup for load balancing, but I would also like them setup for Fail-over and Redundancy.
Can you help me with what commands I need to implement?
Here are my Show Run and Show Interfaces:
sh run Building configuration...
Current configuration : 1153 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname ******** ! boot-start-marker boot-end-marker ! enable secret 5 $1$UNZd$HW7bnkpHzBEoTrmiJ0RBc/ ! no network-clock-participate slot 1 no network-clock-participate wic 0 no aaa new-model ip subnet-zero ip cef ! ! ! --More--  no ftp-server write-enable ! ! ! controller T1 0/0 framing esf linecode b8zs channel-group 0 timeslots 1-24 speed 64 ! controller T1 0/1 framing esf linecode b8zs channel-group 0 timeslots 1-24 speed 64 ! ! interface FastEthernet0/0 ip address 192.168.2.1 255.255.255.0 ip helper-address 192.168.1.10 duplex auto speed auto ! interface Serial0/0:0 ip address 192.168.10.2 255.255.255.252 --More--  ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/1:0 ip address 192.168.10.6 255.255.255.252 ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.10.5 ip route 0.0.0.0 0.0.0.0 192.168.10.1 ip http server ! snmp-server community maumau RO snmp-server enable traps tty ! line con 0 password ******** line aux 0 line vty 0 4 password ******** --More--   login ! ! ! end
CCACore2#
sh int FastEthernet0/0 is up, line protocol is up Hardware is AmdFE, address is 0013.c3b0.6d20 (bia 0013.c3b0.6d20) Internet address is 192.168.2.1/24 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:01, output 00:00:00, output hang never Last clearing of "show interface" counters 03:49:35 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 330000 bits/sec, 271 packets/sec 5 minute output rate 258000 bits/sec, 180 packets/sec 5114330 packets input, 905302478 bytes Received 16761 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 3697809 packets output, 851936037 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets --More--   0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out --More--  Serial0/0:0 is up, line protocol is up Hardware is PowerQUICC Serial Internet address is 192.168.10.2/30 MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 255/255, txload 16/255, rxload 16/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 03:49:36 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
222 Queueing strategy: weighted fair Output queue: 0/1000/64/129 (size/max total/threshold/drops) Conversations 0/41/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1152 kilobits/sec 5 minute input rate 98000 bits/sec, 90 packets/sec 5 minute output rate 98000 bits/sec, 137 packets/sec 2001066 packets input, 380799009 bytes, 0 no buffer Received 1598 broadcasts, 0 runts, 5 giants, 0 throttles 4368 input errors, 358 CRC, 2076 frame, 0 overrun, 0 ignored, 1934 abort 2629752 packets output, 364268950 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 output buffer failures, 0 output buffers swapped out --More--   4 carrier transitions Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags --More--  FastEthernet0/1 is administratively down, line protocol is down Hardware is AmdFE, address is 0013.c3b0.6d21 (bia 0013.c3b0.6d21) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters 03:49:37 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred --More--   0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out --More--  Serial0/1:0 is up, line protocol is up Hardware is PowerQUICC Serial Internet address is 192.168.10.6/30 MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 255/255, txload 29/255, rxload 22/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input 00:00:02, output 00:00:00, output hang never Last clearing of "show interface" counters 03:49:37 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
38 Queueing strategy: weighted fair Output queue: 0/1000/64/38 (size/max total/threshold/drops) Conversations 0/46/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1152 kilobits/sec 5 minute input rate 138000 bits/sec, 95 packets/sec 5 minute output rate 179000 bits/sec, 132 packets/sec 1715359 packets input, 435616673 bytes, 0 no buffer Received 1607 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 2493662 packets output, 486619197 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out --More--   0 carrier transitions Timeslot(s) Used:1-24, SCC: 3, Transmitter delay is 0 flags CCACore2#
How best to set this up will depend upon the specifics of your environment and your requirements. Easiest is a simple MLPPP setup, most robust is redundant LANs feeeding redundant routers through physically diverse T1 to full redundancy at the other end. Inbetween are all shades of grey...
Availability -- Load Sharing -- Cost/complexity You only get to chose two out of three...
Good luck and have fun!
