Need help setting up DDR with async
Apr 30, 2005 0 Replies
Hello, need someone to help me get DDR to work with 1760-V, using onboard cisco modem wic-1am, that will be using pots to connect to a PERLE connection bank (of modems) in my corporate office. I've researched and tried but it's all too damn confusing...
Here is my basic condition, want wic-1am to dial-up using async (pots) when t-1 connected to vwic 1mft-t1 circuit goes down... seems pretty simple, but maybe i'm making it too hard...
Anyone with experience, please look at my current config and please tell me how to modify...
thanks for any help
AL
Conf t hostname Store129
tdm clock T1 0/0 both export line ip subnet-zero
enable secret
ip dhcp excluded-address 172.16.129.1 172.16.129.100 ip dhcp excluded-address 172.16.129.106 172.16.129.254
ip dhcp pool 0 network 172.16.129.0 255.255.255.0 default-router 172.16.129.254
controller T1 0/0 framing esf linecode b8zs channel-group 0 timeslots 1-2
interface FastEthernet0/0 ip address 172.16.129.254 255.255.255.0 speed auto no shut exit
interface Serial0/0:0 no ip address encapsulation frame-relay frame-relay traffic-shaping
interface Serial0/0:0.1 point-to-point ip address 10.0.129.2 255.255.255.252 frame-relay interface-dlci 1002 class map_vofr vofr data 4 call-control 5 exit
router eigrp 100 network 10.0.0.0 network 172.16.0.0 no auto-summary no eigrp log-neighbor-changes
ip classless no ip http server ip http access-class 1 ip pim bidir-enable exit
conf t map-class frame-relay map_vofr frame-relay cir 64000 frame-relay bc 640 frame-relay mincir 64000 no frame-relay adaptive-shaping frame-relay fair-queue frame-relay voice bandwidth 16000 frame-relay fragment 80 exit
call rsvp-sync
voice-port 2/0 echo-cancel coverage 32
voice-port 2/1 echo-cancel coverage 32
dial-peer cor custom
dial-peer voice 1 pots destination-pattern 7129 port 2/0
dial-peer voice 2 vofr destination-pattern 7... session target Serial0/0:0 1002
dial-peer voice 3 vofr destination-pattern 5... session target Serial0/0:0 1002
dial-peer voice 4 vofr destination-pattern 3.. session target Serial0/0:0 1002 exit
line vty 0 4 password login exit exit
