Configuring an inside nat group on inside interface
Apr 10, 2006 2 Replies
Here is an interesting problem.. I am missing something very simple.
I have a pix that I want to setup as a vpn server. I am using the easy client software. I have a pool of ip addresses. This is a pool that I picked out of the blue not in use, 192.168.254.0/24. I have no problem getting the remote client to authenticate and get an ip address from the pix in this range.
I do not have any control of the internal router, 172.16.0.1. The inside interface has an ip address on the inside network, 172.16.0.2 and I have confirmed connectivity. If I put in the correct routes, I can ping from the pix to anywhere without any problems.
Here is what I need to do though. I need to have the 192.168.254.0 network natted on the inside. That way, when I get an ip address from this pool and try to ping from a client computer with a 192.168.254 address, as far as the inside is concerned, I am coming from a
172.16.0.0 address and not a 192.168.254.0 address.
Can it be done?
Turn the PIX backwards, attach the VPN to the "inside" interface, connect that to the internet, put 172.16.0.0 on its outside interface, connect that to the LAN, turn off nat 0 access-list for the VPN. Packets accepted on the inside interface VPN will have their source address PAT'd as they go out the outside interface into the LAN .
You could possibly accomplish the same thing using reverse NAT, with a "nat (outside)" and "global (inside)" pair, but I'm not positive it can be done that way -- it depends on whether the PIX will proxy arp on the inside interface on behalf of reverse-NAT'd IPs. Usually routing is checked before NAT, and you have a problem because the PIX will notice that the destination is in the same network as the inside interface and so will drop the packets. You -might- be able to get around that by putting in static routes for the individual 172.16/16 IPs that you want to front the VPN users under.
hmmm.. i am not sure how I would begin to do that.
Internal Lan - 172.16.0.1 --- 172.16.0.2 Inside Pix Outside Pix ---
24.1.1.1 | |
---192.168.254.0 (Pool of IP addresses)
I need to basically nat 192.168.254.0/24 to look like it is coming out of 172.16.0.2
John
