Inside access to DMZ
Mar 24, 2006 1 Replies
Hello. I have an internet line that goes directly into a cisco 2600. this 2600 is connected to the PIX 515E and forwards all IP's to it.
My 515 has 3 if's
  1. inside (192.168.0.X 255.255.255.0)
  2. outside (REAL IP)
  3. DMZ1 (REAL DMZ IP)
I can't access from inside to the DMZ1. Outside to DMZ1 works just fine.
Can someone write down the Statics i need to enter?
Thanks!
Meni Milstein.
You don't need statics to get to the DMZ from the inside. What does your NAT config look like on the Pix?
Chris.
