Flow Inside-outside change only destination port
Apr 20, 2005 1 Replies
Hello everybody out there using Pixes
I have a question regarding the change of destination port on PIX
My intention is to chage from:
SRC 10.50.50.13:7689 DEST 192.90.90.90:10000
TO
SRC 10.50.50.13:7689 DEST 192.90.90.90:443
The flow is from inside->outside, I tried using and static that look like this
static (outside, inside) tcp 192.90.90.90 10000 192.90.90.90 443 netmask 255.255.255.255
But I realize that the static conversion in this flow try to change the source of the packet not the destination and what Im really doing with the sentence above is saying something like "everything that has source
99.90.90.90 10000 now must be known as 199.90.90.90:443" obviously this does not work
How can I add the sentence that im looking for??
Thanks in advanced
Lalo
In article , Lalo wrote: [PIX]
:My intention is to chage from: :SRC 10.50.50.13:7689 DEST 192.90.90.90:10000 :TO :SRC 10.50.50.13:7689 DEST 192.90.90.90:443
:static (outside, inside) tcp 192.90.90.90 10000 192.90.90.90 443 netmask
255.255.255.255
That should work.
:But I realize that the static conversion in this flow try to change the :source of the packet not the destination
No, you reversed the interfaces, so it will affect the destination.
:How can I add the sentence that im looking for??
Did you 'clear xlate' after making the change?
