NAT VPN Issue
Jun 29, 2005 2 Replies
Pardon if im still alittle green around the gills....
I have a PIX515e that is setup for VPN service to outside clients using a preshared key. Internall we are using 192.168.12.x for addressing of our servers. I have several client show are mapped in via VPN, and able to connect, but i have a new client that is already internally using that subnet.
The question: Can i NAT one instance of the VPN for this one user?
Thanks in advance
Create a new vpngroup that uses a different ip local pool than the standard VPN clients. Then you can do NAT for this client only.
Its my internal address that is causing the problem. They want me to NAT the address, to another subnet so they can use it. Im not sure if i can NAT based on the destination address, or the VPN Group? And if it is possible how to accomplish it.
Thanks! L
