My clients connects slowly to my cisco switch
Sep 21, 2006 4 Replies
Jump to replies (4)
My clients connects slowly to my cisco switch open original image
I have just replaced my old HP switch with a cisco C2960 48TTL switch. If I have a booted client and plug its network cable into the switch it takes long time to get an ip address. I newer had this problem with the old HP switch. The dhcp service (from a network server) works perfect in the rest of my network environment (HP switch).
I think it has something to do with the auto sense, hardware negotiation or what it is called.
Do I need to configure something to speedup the process?
Best Regards Martin
Take a look at the spanning-tree portfast option on your interfaces.
You'll find that the switch doesnt enable the port (to a green light) for about 30 seconds while it gathers information about what is connected (it has orange light during this phase)
HTH....M
Do I need to enter the: no spanning-tree portfast command on the interfeces?
Regards Martin
Mike J wrote:
On ports connected to PCs you should use:-
There are other optimisations that you can use too but I don't bother since the benefit is smaller.
switchport mode access ! prevents trunk negotiation
This document is a bit old but explains the principles.
PortFast and Other Commands to Fix Workstation Startup Connectivity Delays
Finally you should consider enabling bpduguard on ports with portfast enabled.
In many environments this is not an issue, our users only re-boot their PCs, well never ideally:-)
> says:-
Try
"set port mode host" (or set port host - long time since i did this) this is a macro which alters 3 different settings to get a port to come up as fast as possible.
> Using PortFast and Other Commands to Fix Workstation Startup
