Multicast Limits
Dec 04, 2007 3 Replies
Jump to replies (3)
Multicast Limits open original image
I wonder how many simultaneous video multicast streams a layer 3 switch can support (assumption one stream = 2 Mbps)? using only layer 2 (IGMP) source and receiver on the sme VLAN using layer 3 routing (with PIM) I can't find any precise info on cisco web site. Any idea or experience ?
Thanks.
it really depends on the switch.
we did some scale tests on a Cat 6509 and it was happy with several 1000 multicast streams (any more and we ran out of bandwidth, so irrelevant to us).
FWIW we use 5 Mbps MPEG2 for video streams (2 Mbps seems a bit optimistic if you want high quality), and 100 Kbps for low bandwidth audio - notional load expected is 100 video and 400 audio, so around 450 Mbps aggregate.....
scale test from a european test lab:
(the lab is
if you need someone to test for you).
(the
Thanks for the information and the link (testing setup is well described) Any idea if some tests have been performed to compared performance of products from other companies ?
i have seen a few tests for other boxes - try eantc and other test houses
i remember is:
also try
but - your best friend for this is Google and the info on which comparison you want.....
