Multicast on LAN
Mar 05, 2007 4 Replies
Jump to replies (4)
Multicast on LAN open original image
I have a Cisco 4510 set up as my core switch. It has several vlans for several networks. I have Catalyst 3550's in the wiring closets were all my end users are connected. I have approxametly 300 endusers. I want to set up multicast accross the network. Any quick and dirty set ups? Thanks
Just turn on "ip multicast-routing", and your multicast will go between VLAN interfaces. If you want to go more advanced, look for "CGMP" and "IP PIM". There is not that much to configure for a multicast.
Good luck,
Mike
------ Headset Adapters for Cisco IP Phones
enable ip multicast routing and then apply "ip pim sparse" on the vlan interfaces which need to take part in mrouting.
Sounds too easy. Would I need a Rendezvous Point on the core? Should I enable CGMP and IGMP on all switches?
If you want to use only Source Specific Multicast, you will not need an Rendezvous Point. Otherwise you configure one and BSR on all routers.
If your switch offers IGMP snooping: Enable it on the switch.
If your switch does not offer IGMP snooping, check for CGMP and enable it on the switch and all routers connected to this switch.
If your switch does offer neighter IGMP snooping nor CGMP, mark it red and consider traffic limitations for multicast on the connecting routers.
