vlan and multicast
Nov 23, 2007 2 Replies
Hello
Let a switch with 3 port based vlans, vlan id 1, 2 and 3 with IGMP snooping (basic layer 2 network) On vlan 1 and 2 there are video multicast sources. A video monitor connected on vlan 3 should be able to receive both multicast stream. If the port where video monitor is connected belong to vlan 1, 2 and 3, could the video monitor receive both streams after IGMP registration ? What are the pros and cons ? Thanks for your help.
Another question : are source address of multicast frames translated with NAT ? If yes how to identify the source of the multicast once gone through the NAT ?
dk
homework time?
IGMP is about devices telling the local router interface what groups they want.
multicast routing is then needed to pass multicast packets between them
So - not unless there is a L3 box somewhere to act as a multicast router (which is probably what would handle the IGMP stuff).
and on some Cisco boxes multicast requires an additional licence - eg if the VLAN switch is a Cat 3560 / 3750 then it will need whatever Cisco are calling an enhanced image this week.
er - it doesnt work unless you add more functionality?
not if they dont pass thru a NAT function :)
not really, I plan to buy a used ethernet switch that could deals with vlan (port based) and IGMP but I prefer to be sure I will the get what I need. On 2 different VLAN, I have two stations with USB webcam that multicast video stream. I want to monitor these streams from a 3rd vlan. Because a VLAN define a broadcast domain, I was thinking that if the port where the monitoring station is connected could be in several VLANs (1 2 and 3) at the same time, it could receive stream of vlan 1 after IGMP registration and/or stream from VLAN 2 after another IGMP registration. Adding a layer 3 box may be more expensive.
