MPLS & transparent bridging
Aug 19, 2005 4 Replies
Jump to replies (4)
This is kind of expected since you should not bridge between "L2" and "L3" interfaces. I'm not sure that MPLS is supported with IRB but if it is, then soulution would be:
bridge irb bridge 1 protocol ieee
int gi0/0.2 encapsulation dot1Q 2 bridge-group 1 int gi0/0.3 encapsulation dot1Q 3 bridge-group 1 int gi0/0.4 encapsulation dot1Q 4 bridge-group 1 int bvi 1 ip address x.x.x.x x.x.x.x tag-switching ip
Hi! I want to configure a tag-switching on a subinterface. But I already have two subinterfaces in a bridge-group. The config I want to have looks like:
int gi0/0.2 encapsulation dot1Q 2 bridge-group 1 int gi0/0.3 encapsulation dot1Q 3 bridge-group 1 int gi0/0.4 encapsulation dot1Q 4 ip address x.x.x.x x.x.x.x tag-switching ip
But trying to do so I get an error:
% MPLS not supported on interface GigabitEthernet0/0.4 Transparent bridging already configured
How can I figure out? May be there is another solution to this network model?
That's not actually what I want to achieve. gi0/0.4 _MUST NOT_ be the member of bridge-group 1.
What DO you want to achieve then? What is the requirement? Why did you put bridge group on gi0/0.4 in the first place?
I want to have 2 subinterfaces in a bridge group and 1 subinterface with tag-switching configured.
I did no put bridge group on gi0/0.4. It is not a member of a bridge group.
