Problem with NPE-G1
Jan 07, 2006 1 Replies
Hello I've Cisco 7206VXR (with NPE-G1) router connected to Catalyst switch over copper 1000BaseT connection. Every time When I'm adding subinterface at Gi0/1 the whole Gi0/1 went, eg:
conf t int giga0/1.200
Then on switch:
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Configuration:
7200:
interface GigabitEthernet0/1 no ip address duplex full speed 1000 media-type rj45 no negotiation auto no cdp enable no clns route-cache
3650G:
interface GigabitEthernet0/1 switchport trunk encapsulation dot1q switchport mode trunk load-interval 30 speed 1000 duplex full no mdix auto no cdp enable end
7200 is running 12.2(25)S4, and the Catalyst is running 12.2(25)SED1. The cabling is 100% OK. Any recommendations or advices ?
Earlier Giga0/1 was connected to other Catalyst over 1000BaseSX (using SX GBIC at NPE-G1) connection - and earlier there was no problem...
Thanks, RobertH
This would be because of the Autostate feature of the Catalyst switch. Just check the following link :
Bye Hyder
