Routing Between Two VLA Ns
Feb 05, 2007 5 Replies
Jump to replies (5)
Tomorrow morning I need to set up routing between two VLANs on a 2950. Both VLANs need access to outside but traffic is not allowed to flow between them. The router is a 3745.
This will be my first time doing this so I'd appreciate it if someone would check my configs and verify that I'm not missing anything.
Here's my config for the switch: int f0/1 switchport mode trunk switchport access vlan 1 switchport trunk native vlan 1
Here's my config for the router: int f0/0 no ip address int f0/0.1 encapsulation dot1q 1 ip address 192.168.195.25 255.255.255.252 int f0/0.2 encapsulation dot1q 2 ip address 172.16.98.1 255.255.255.0
Here's how I propose to prevent access from one VLAN to the other. Will this work? Does the access-group get applied to the major interface or the subinterface?
ip access-list extended no_route deny ip 192.168.195.0 0.0.0.255 172.16.98.0 0.0.0.255 deny ip 172.16.98.0 0.0.0.255 192.168.195.0 0.0.0.255 permit ip any any
int f0/0 ip access-group no_route in
Your configuration looks pretty good. One question, is the mask on f0/0.1 really a /30? If so, you'll want to change your ACL a little. (see below) Personally I like to hard set my speed/duplex settings, but that's just me. This is how I would configure things:
[switch] int f0/1 switchport mode trunk duplex full speed 100 [router] int f0/0 full-duplex speed 100 no ip address int f0/0.1 encapsulation dot1q 1 ip address 192.168.195.25 255.255.255.252 ip access-group no_route in int f0/0.2 encapsulation dot1q 2 ip address 172.16.98.1 255.255.255.0 ip access-group no_route in
ip access-list extended no_route deny ip 192.168.195.24 0.0.0.3 172.16.98.0 0.0.0.255 deny ip 172.16.98.0 0.0.0.255 192.168.195.24 0.0.0.3 permit ip any any
Hope this helps,
-Dan
Thank you for pointing out the discrepency between the IP address mask and the ACL wildcard mask.
Can you please explain why the access-group statement is applied to the sub-interfaces instead of f0/0?
The ACL needs to be applied to the interface that will "see" the traffic. f0/0 acts only as a layer ONE device in this case - and therefore will not "see" the layer THREE traffic you are trying to filter.
Try to think of the sub-interfaces as "real" interfaces. This makes it easier to think about.
Thank you. I see some other commands that are currently associated with F0/0 that would seem to fall into this category: ip nat inside ip nbar protocol-discovery service-policy input PMap_Vendor
I presume these should all be moved to one of the sub-interfaces as well. Is that correct?
Yes. Having them on the fa interface doesn't do anything.
