module memory on 7600
Oct 26, 2006 3 Replies
Jump to replies (3)
module memory on 7600 open original image
Anyone know how to tell how much memory a module on a 7600 has? In particular I'm wondering about the ws-x6724-sfp (24 port sfp GigE) and WS-X6748-GE-TX (48 port 10/100/1000 copper Ethernet). I don't see it in "show ver", "show diagbus" or anywhere else in "show tech". There is a diagnostic test for memory on a line card, but a "show diagnostic result module 1 detail" command doesn't look like it would show the memory size, only errors (and the test is rather disruptive). I did get a look at the memory before installing the modules. One of them had
256MB printed on it, and that's what I wanted. The other one didn't state its size explicitly, but the chips on it (8 + 1 for parity) did have 256 in the middle of a string of numbers and letters, so I feel fairly certain about that one. If someone knows a command to find this information though, it would save me some driving to other sites.
Thanks!
You may wish to investigate:
Maintaining System Memory
Hope this helps.
same as always I'd say, like this ?
ServerSwitch#sho module Mod Ports Card Type Model Serial No.
----------- ........ 3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP ......
ServerSwitch#attach 3 Trying Switch ... Entering CONSOLE for Switch Type "^C^C^C" to end this session
ServerSwitch-cfc3#sho ver Cisco Internetwork Operating System Software IOS (tm) c6lc2 Software (c6lc2-SP-VM), Version 12.2(18)SXF5, RELEASE SOFTWARE (fc3) Technical Support:
(c) 1986-2006 by cisco Systems, Inc. Compiled Sat 08-Jul-06 06:57 by kellythw Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(14r)S5, RELEASE SOFTWARE (fc1) BOOTLDR: ServerMO uptime is 3 weeks, 3 days, 22 hours, 12 minutes System returned to ROM by power-on Running default software
cisco Catalyst 6000 (SB1121) processor with 245760K/16384K bytes of memory. Processor board ID SAL1033Y5V9 SB1121 Processor (Rev 32) SB-1 CPU at 400Mhz, Implementation 1025, Rev 0.3 Last reset from power-on X.25 software, Version 3.0.0.
123K bytes of non-volatile configuration memory.
Configuration register is 0x100 ServerSwitch-cfc3#
The memory on line cards is used for packet buffers. Check out the data sheet for the card which will tell you how much memory each port has for packet buffers.
Scott
