is there a CLI command to view single or all mac-adresses of active nodes connected to a single or all ports of a 16/36 port fastethernet module in a cisco 3725/3745/3825 router?
TIA, Stefan
I've never run a switch module in a router, but I would guess show arp, show cam dynamic, or show mac-address-table would have to work. And in theory, show arp should work along with one of the other two to support layer 2 troubleshooting.
Read the full replyHi,
TIA, Stefan
Hi Stefan,
sh mac-addr
usually does this for me on a 3750 (a Layer 2 device), however for a Router (Layer 3) you probably need to start with
sh arp
Cheers.............................pk.
The 16/36 port FastEthernet NME module is a 3750 on a stick. It is managed and configured completly independent of the router. You need to telnet to the module, or "session" to it from the router. You would then use the "show mac-address" command to show all of the known MAC addresses.
