modem init string
Apr 26, 2005 2 Replies
I want to create a new modemcap B based on an existing one A.
Right now to do it, I have to run "modem type autoconfigure type A" under debug mode to capture the debug string, and then change this tring for modemcap B.
Is there any command displaying the init string of the stock modemcaps ?
Thanks,
DT
~ I want to create a new modemcap B based on an existing one A. ~ ~ Right now to do it, I have to run "modem type autoconfigure type A" ~ under debug mode to capture the debug string, and then change this ~ tring for modemcap B. ~ ~ Is there any command displaying the init string of the stock modemcaps ~ ? ~ ~ Thanks, ~ ~ DT
router#show modemcap
gives you a list of all the built-in (or user-added) modemcaps
shows you what's in MODEMCAPNAME
Aaron
Oh, I feel shameful of not being to find out that. Thanks a lot, Aaron.
DT
