Cisco 525 and PDM
Jun 09, 2006 2 Replies
Hi gents, I've always managed little cisco pixes and now i have to manage a 525. First of all I noticed that telnet was the way to connect, I used to connect with ssh. Is there any advantage or problem to change this ? I feel more secure with ssh
I also noticed PDM isn't enabled, I know it's for security issues, but it would help for disabling access-lists easier . Is there any disadvantage enabling the pdm in the 525?
what lines are necessary to configure pdm access ? is this enough?
http server enable http 172.16.0.0 255.255.0.0 inside
Hope you can help me thanks in advance.
Are you sure you're using a 525 and not a 520? If you have a 520, you might have a 2mb flash card that won't hold the PDM images. Try running 'show version' and see what it says. If it reads something like 'Flash E28F128J3 @ 0xfff00000, 16MB' then you've enough room to install it. You can 'ls flash:' to see what files are there currently. You may also be running a pre-PDM version of Finesse. Posting some more details will help us to better help you with your issue.
-Gary
It's a 525 for sure, I think that it doesn't have pdm and ssh active.
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz Flash E28F128J3 @ 0x300, 16MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Is it possible pdm ?
Gary ha escrito:
