Linksys Private Virtual Edge scenario...
Aug 16, 2006 1 Replies
Linksys Private Virtual Edge scenario... open original image
I was advised to post this here as Linksys is a Cisco subsidary ;-)
We wonder if we can use the Linksys SRW2016 PVE feature to be able to enable/disable internet access in selected classrooms in a school. I think I have figured out how to set up the PVE stuff. However if possible I just want to have confirmed that this solution (how I think it should be set up) is going to work.
A simplified sketch of the setup can be found here:
I plan to divide the switch into two PVEs, first for port 1-7 with port
8 as uplink. Port 8 is connected to the domain controller etc and this is also the port which should be used to administer the switch.
The second PVE (blue connections) is for port 9-15 with port 16 as uplink. The latter is connected to the firewall. This is for distributing the internet connection. In each classroom the teacher should be able to connect/disconnect the blue cable to the classroom switch (internet connection for his classroom) without affecting the other classrooms' internet access.
Will this work, and if yes is there any side effects? We have no spanning trees or other 'features' enabled..
How about administering the switch, this is normally assigned to VLAN ID #1, how will the be affected using PVE...? I need to administer this box through its port 8 and I don't want to lock myself out as this switch has no reset button :-|
If this will not work, do you have other suggestions to solve this not needing huge investments ;-) ??
Thanks for any comment or feedback on this. The user guide for the SRW20nn switch series can be found at the Support / Downloads section at
regards
geir
Hi Geir,
You may also wish to investigate Tek-Tips Linksys Networking Solutions Forum:
Hope this helps.
Brad Reese Cisco Technical Forums
