We have two separate LANs (LAN1 and LAN2) which should have NO communication between each other. They are connected to the internet via a firewall with two VLAN ports.
I need to access both of these LANs from a separate computer. Unfortunately our fiurewall does not have 3 VLAN ports so I cannot achieve this through it.
However on LAN1 we have a Linksys SRW224 managed switch with a few spare ports. Say I connect LAN2 to port 23 and to port 24 I connect the computer needing to access both LAN1 and LAN2. Is it possible to configure this switch to achieve this?
Summary, Linksys SRW224 Port 1..22 normal switch operation for LAN1 and connection to port 24. Port 23: Connected to LAN2 completely waterproof to/from LAN1 (port 1..22) but connection to port 24.
If this is possible with this device, how would I configure it using the webview utility?
Thanks a bunch if somebody have comments and info
greetings
Geir
