eigrp doesn't need net mask ?
Aug 16, 2006 2 Replies
Most relevant reply
Bod43
You need to understand the function of the network statement. It only tells the router on which interfaces to do eigrp. It does not influence eigrp in any other way. int e0 ip address 192.168.0.1 255.255.255.0 int e1 ip address 10.1.2.3 255.255.0.0 router eigrp 1 network…
Hello there :D
Here's what bothers me,.i'm so curious about it. I found that when setting eigrp, i don't need to put network mask. Like this:
(config)#router eigrp 1 (config-router)#network 10.1.1.0
and i should perform the following command to advertise it: router(config-if)#ip summary-address eigrp 1 10.1.1.0 255.255.255.0
why does eigrp work in this way ? Not using network mask on the router configuration gives some advantages ?
When no wildcard mask is specified, EIGRP simply assumes the classful mask for the specified network. However, EIGRP does allow you to specify a mask if you wish something other than the default classful mask to be used.
In your example above, even though you specified "network 10.1.1.0" you will see that the running configuration will show "network 10.0.0.0" because the classful mask got applied. The reason for the mask being optional probably traces its roots back to the IGRP protocol from which EIGRP evolved and which is a classful routing protocol.
Cisco da Gama htpp://ciscostudy.blogspot.com
router eigrp 1 network 10.0.0.0 !! An exactly equivalent network statement would be network 10.1.2.3 0.0.0.0 ! ie a single host
There is exactly no difference between them.
