Cheapest 1U Switch With Private VLANs?
Sep 24, 2006 1 Replies
www.BradReese.Com
Hi Will, You may wish to investigate the Cisco Switch Product Advisor: this tool you can also view immediately the pricing for each switch. Furthermore, you may wish to call 1-800-745-7381 in the USA or Canada between 8:00 A.M. and 8:00 P.M. EST. Your local Global Cisco…
Cheapest 1U Switch With Private VLANs? open original image
What is the cheapest Cisco switch that supports private VLANs, with one port used to uplink to a router or firewall port, and the remaining ports configured as completely private? I'm not sure how Cisco defines PVLAN, but the key attribute I must have for this product is that all data must pass from a private port to the uplink port, with no possibility for broadcast, arp, or layer 3 traffic to travel between private ports. This must be true even if the host attached to a private VLAN port can impersonate a different MAC address other than its own, and must be true even if the host knows the target MAC address of a host on a different VLAN port.
Since I will be using one of these switches for each segment attached to a firewall, and the number of hosts are trivially small, I have no concerns about density or about passing VLAN information across multiple switches.
What are my product options? I would like to identify both a fast ethernet and a gigabit switch.
Hi Will,
Using this tool you can also view immediately the pricing for each switch.
Your local Global Cisco Pre-Sales Contact Information:
Hope this helps.
