In Rack -48V DC Rectifiers
Jun 13, 2007 5 Replies
Jump to replies (5)
Any recommendations for in rack rectifiers to supply -48V DC in the
25A to 50A range? I know about Emerson/Lorain and Unipower-Corp.
It would be helpful if they had these characteristics:
--19" rack compatible
--hot swap modules
--remote monitoring capable
--easy to get maintenance contract in, at least, urban areas and parts readily available
--1 or 2 RU
Thanks.
APC makes some DC power stuff that I've liked.
I don't think you're going to get 50A in 2U of space though. The others I have are 5A in 1U, 10A in 2U/3U.
On Jun 13, 4:39 pm, Doug McIntyre wrote: ...
Thanks for the lead on APC.
Unipower model TRSI7000 claims 52.1A at 48V in a 2U form factor.
Tyco seems to meet most of your needs. Take a look at their CPL platform.
If i read the specs correctly. Tyco can output up to 200A @ 50V in a 1U rack space.
be carefull when utilizing rectifiers, some are designed to be operated when connected to batteries, if utilizing battery then output may not be as clean.
