1841 - rack-mount?
Apr 11, 2005 1 Replies
Walter Roberson
:AFAIK the 1841-Router is not rack-mountable per se (i.e. the box is :Does anybody know if there's a rack-mount-kit availble that allows it to :be mounted in a standard 19" rack? Try a standard rack-mount "shelf" -- a shelf that you rack-mount and place whatever you want on top…
AFAIK the 1841-Router is not rack-mountable per se (i.e. the box is smaller than the standard 19" rackspace).
Does anybody know if there's a rack-mount-kit availble that allows it to be mounted in a standard 19" rack?
Thanks much in advance for your help,
-ewald
In article , Ewald Jenisch wrote: :AFAIK the 1841-Router is not rack-mountable per se (i.e. the box is
Try a standard rack-mount "shelf" -- a shelf that you rack-mount and place whatever you want on top of.
