I wanted to learn how to implement QoS so I was going to implement both an IntServ and DiffServ model to learn about them in a small home network but I'm not clear on if this is possible for such a small application. In the end, my goal is to figure out what is best for a small LAN with a few dozen voice, video, and data apps that will send locally as well as outside the LAN.
Also, another question is, I've read that QoS (e.g. IntServ) requires several functions on routers and switches along the path like admission control, classification, policing, queuing and scheduling. But say I have all this gear, and one of the hops in the network is done over radio and this radio may have to travel very long distances. Does QoS still work then?
Hi,I should implement a QoS Concept in a given network.The main components...
F
fugettaboutit
Hello,
Most modern networks don't follow the IntServ model, and really for the reasons you listed. There are limitations with protocols like RSVP. In fact, it is possible for RSVP to signal a path as "adequate" if insufficient bandwidth is present in an intermediate hop. There's also a lot of overhead managing and signaling resources...RSVP manages at the flow level. Imagine an interface with hundreds or thousands of flows. In short, IntServ doesn't scale as well as the DiffServ model.
You'll find that DiffServ works well, and is the method chosen by most network engineers today. It (somewhat) addresses the issue of crossing network domains, that is, networks not under your administrative control. End-to-end QoS can be challenge in these environments, but because DiffServ is implemented in a per-hop-behavior (PHB) fashion, you have a much more scalable scenario. Of course, the provider has to adhere to your classification scheme or at least provide some equivalent mapping. MPLS providers will do this, but I don't believe they will offer anything beyond the class of service (ToS) in terms of classification (a handful of classifications, typically "gold, silver, bronze, and default" classes). I don't believe there are providers out there that provide full DSCP class support.
Anyone out there confirm or deny this thought about provider support? :-)
In your home lab environment, you may find it not a terribly good ROI to implement fancy QoS mechanisms. :-) That's *not* to say QoS doesn't have its place in a LAN environment, especially an enterprise LAN with a large traffic mix. I think you'll find yourself very bandwidth-rich, and QoS won't benefit you much (if at all) in your LAN unless you can saturate some of the interfaces. Now, as for the WAN port, you can influence the outbound interface queues for sure as different packet sizes and associated interface delays change things just a bit. You could classify your traffic with appropriate ACLs, integrate them into your traffic policy, then apply that policy outbound on your WAN interface. You have the most control outbound. You can implement service policies inbound, but you don't have control of what the Internet hands you. In the case of voice, you can use/tweak de-jittering buffers to play back the packet stream predictably. You can also apply your traffic policies to the inbound traffic, but keep in mind that there is an order of operations that Cisco IOS uses when dealing with the processing of inbound vs. outbound QoS. For your situation, I'd concern myself with outbound traffic. Again, you'll not really have much control on what your provider hands back to you...the Internet is best-effort only. ;-)
Here's a template for you to start with:
class-map match-any Outbound-Voice match protocol rtp class-map match-any Default
policy-map SDM-Pol-Serial0/0 class Outbound-Voice priority percent 70 set dscp ef
You can add more classes and modify the policy map as appropriate. As an aside note, I utilize similar QoS tools in my network. I have a couple of sites that are driving some of the WAN circuits into the ground. My server group sometimes likes to fire off backups in the middle of the day. I will see average utilizations of 99 percent for hours at a time. In fact, with a display threshold of 90% at the 95th percentile (top 5 percent of traffic spikes per sample are removed), I see averages at 98% for the sample period! The point is, these circuits are severely abused. To add to the challenge, we hand off a fair amount of voice traffic to these sites, as they also provide T1 PRI gateway services. Guess what? The Cisco IOS provides solid performance with such abuse. I see lots of discards on non-voice traffic, but voice gets just what it needs. We utilize the SAA features in IOS, and we see jitter stats that vary by only a few milliseconds and consistent MOS scores of over 4.5 for voice quality. In past work environments, I've worked with ATM networks. It's surprising to see how well QoS tools perform relative to protocols like ATM that are designed from the ground up to deal with converged traffic!
Good luck with your lab!
-Cisco guy from Fort Wayne, Indiana
William Zumwalt wrote:
A
Arthur Brain
The provider I am currently dealing with on a voice project to provide "QoS" between multiple WAN sites only provides two classes of service, "Business" and "Interactive". They assign Diffserv Codes 4+ as "Interactive" and anything below as "Business".
FOr this reason we have changed the voice-signalling up to 5 so it gets the same priority as Voice over the Data. This isn't a problem as signalling isn't too greedy at all.
I use AutoQoS on the Cisco switches, and as the IP voice devices are a mixture of non-Cisco devices whose "support" organisation has no comprehension of IP, let alone VoIP (don't get me started...why would they sell VoIP gear to my poor bloody customer but not have anybody who understands even subnet masks?????), I configure each of the edge- switch ports as Trunks to "Trust" the QoS on the received frames, and use Ethereal whenever the voice "support" people have been in the building to see what the Diffcode/QoS settings are today...
J
James
We use BT's (British Telecom) MPLS service globally (US, Norway, Switzerland, Egypt, China, Malaysia, Russia, Ukraine, Philippines, France, Australia etc etc) and they support many PHB's including EF, AF1, AF2, AF3, AF4 etc.
It Works really well I mark my Voice EF, Signaling AF11 and Video AF41. BT accept our markings and map to the corresponding class on their network.
Additionally we distribute aour routes into their network using OSPF.
James
Report Content
ASAP.
