HSSI Port, larcoms Orion 4000, Tons of abort/crc errors
Apr 15, 2005 0 Replies
Hello and thanks for the help. I have 7513(hssi)larscom orion 4000 -- 6T1's -- Larcoms orion
4000(hssi) 3600. I am not using the mega T1. I've included some show interfaces of each router. I'd appreshate any help.
*********** Show Interfaces *************************
7513; Hssi8/0 is up, line protocol is up Hardware is cxBus HSSI Description: Region14 Internet address is 10.1.175.249/30 MTU 4470 bytes, BW 45045 Kbit, DLY 200 usec, reliability 255/255, txload 5/255, rxload 2/255 Encapsulation HDLC, crc 16, loopback not set Keepalive not set Restart-Delay is 0 secs Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/1853 (size/max/drops/flushes); Total output drops: 6218 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 504000 bits/sec, 149 packets/sec 5 minute output rate 911000 bits/sec, 161 packets/sec 31599238 packets input, 4276932616 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 335 giants, 0 throttles 0 parity 70690 input errors, 24533 CRC, 45822 frame, 0 overrun,, 0 abort 30238940 packets output, 2870499628 bytes, 0 underruns 0 output errors, 0 applique, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 139 carrier transitions
3600; Hssi2/0 is up, line protocol is up Hardware is M1T-HSSI-B Internet address is 10.1.175.250/30 MTU 4470 bytes, BW 45045 Kbit, DLY 200 usec, reliability 255/255, txload 2/255, rxload 4/255 Encapsulation HDLC, crc 16, loopback not set Keepalive not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 2w2d Queueing strategy: fifo Output queue 0/40, 210079 drops; input queue 0/75, 0 drops 5 minute input rate 831000 bits/sec, 147 packets/sec 5 minute output rate 491000 bits/sec, 137 packets/sec 161451237 packets input, 3901030929 bytes, 0 no buffer Received 24768 broadcasts, 4 runts, 5606 giants, 0 throttles 0 parity 689549831 input errors, 311694935 CRC, 0 frame, 219859 overrun,
160 ignored , 377634877 abort 169438184 packets output, 4091592774 bytes, 0 underruns 0 output errors, 0 applique, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 4274 carrier transitions LC=down CA=up TM=down LB=down TA=up LA=down
*********************** thanks again.
