In CISCO IOS prefixing a routing command with "no" will make it inactive. But that still leaves a pair of entries in the show config listing. How can I REMOVE a command entirely from showing up in the show config?
Thanks for your help
Yes, in the -running- configuration. Yes, in the -startup- configuration. Save the running configuration as the startup configuration. copy run start
Read the full replyIn CISCO IOS prefixing a routing command with "no" will make it inactive. But that still leaves a pair of entries in the show config listing. How can I REMOVE a command entirely from showing up in the show config?
copy run start
