Does anyone know how to configure 2950 switch to synchronize time with Windows server ?
How to configure 2950 switch to synchronize time with Windows server?
Jul 04, 2007
Run and ntp server on the Windows system and use the line sntp server on the Cisco I don;t think that IOS will use Windows time protocol.
I think that it is OK with later windows servers (2003 on) but that ntp is broken on Windows 2000. YOu can use a third party ntp server of course. I forget which one I used, only that it was open source or similar.
give tftpd32 a try
hans
nh1.homeip.net
I enabled windows 2003 NTP server for test but switch still show unsync ...
Hi Hans, The tftpd32 works well on the time sync with my 2950 switches , thank you. However, do you know how to use windows 2003 ntp server for this?
I tried 2000 and Xp with no success, there were some datailed papers at ms technet about ntp the ms way -- it was basically a stripped version of sntp
-- just good enough for ms. Maybe 2003 is any better -- good luck
hans
nh1.homeip.net
