Hi All,
I'm a newbie,
I have a Cisco Asa 5510,
I need that an ip on the DMZ net can communicate with a LAN IP on one port..
Is it possibile ? How can I do it ?
Thanks all.
Marco Arfini
Hi All,
I'm a newbie,
Thanks all.
Marco Arfini
Good luck,
Mike
------ Cisco IP Phone Headset Adapters
Supposing you already have an ACL applied in the DMZ you need to add the statement that you need into that ACL. Moreover, perhaps, you need to define an NAT statement between your DMZ and the Inside interface.
If you post the conf (cleansed of all sensitive information) maybe we might help you better.
Alex.
help you better.
ok, thanks all,
i solved adding a nat from lan ip to dmz ip! thanks again
Marco Arfini
