QoS prior to IPSEC
Sep 25, 2007 2 Replies
I have multiple 1811W routers in the field. All of these connect to ATT managed T1 routers(1841 at all offices).
I have my interface to the 1841 on FA1, the interface gets a full public IP.
I have the default LAN route go through an IPSEC tunnel to my corporate office.
My LAN is setup as BVI1 bridging the VLAN1 and Dot11Radio0 interfaces. I need to apply QoS to the BVI interface, and I"d like to use traffic shaping. I essentially need the following:
384kbps guaranteed bandwidth for SIP traffic(dscp of 'ef')
512kbps guaranteed bandwidth for Citrix The remaining bandwidth fair queued for all other traffic(SMTP, HTTP, etc etc), and bursting to 1.5Mbps whenever it's available.
I need to keep it below the T1's 1.5Mbps, so as not to saturate their WAN link causing voice issues.
Any ideas where to apply the QoS policy-map, and/or how to traffic shape(if possible)? Obviously this has to be done prior to crypto, so I'm assuming it has to be done on the BVI Inbound interface.
Thanks.
check out Cisco doc "Configuring CBWFQ for IPSec VPN"
qos-preclassify command under crypto map
