Help: Something is telnetting to my Cisco's (Ciscoworks?)
Dec 05, 2005 2 Replies
Hi, I'm getting this error message alot on my Cisco boxes.
2005 Dec 02 09:09:42 %MGMT-6-LOGINPASS:User logged in from 10.x.x.x via Telnet
2005 Dec 02 09:09:46 %MGMT-5-ENABLE_FAIL:User failed to enter enable mode from 10.x.x.x via Telnet - max attempt reached
I have 3 services running on 10.x.x.x. These are
CiscoWorks. What's up Gold. Somix - an MRTG graphing package.
Is there a part of Ciscoworks that telnets to my switches and routers ?
where can I look to solve this ?
Thanks guys in advance.
Genki
it is probably your cisco works program thats doing it. first, make sure you have an ACL on your vty lines in the IOS devices
i really dont know what to tell you about Cisco works and where to look though. are you using IDS/IPS'es?
We don't have the IDS configured and employed yet (doing that this week, they are checkpoint IDS's)
The only thing i can think that is doing it is CiscoWorks, why would it need to telnet to my equipment though, perhaps to pull configs ? Why not tftp. I would love to be able to stop this behavior and get rid of these errors.
I don't think I can really acl out the CiscoWorks box as it needs to get stuff to do it's job. It wouldn't seem like a fix.
Thanks for you reply, appreciate it.
Genki
