cisco 2801, ipsec problem with onboard accelerator
Nov 20, 2007 5 Replies
Jump to replies (5)
Hello!
I need to connect two 2801 over fast ethernet with ipsec encryption. I also need ospf so I configuring gre over ipsec:
crypto isakmp policy 15 encr 3des hash md5 authentication pre-share group 2 lifetime 3600 crypto isakmp key hryakwesdxc address 192.168.200.241 ! ! crypto ipsec transform-set hryak ah-sha-hmac esp-aes 256 mode transport ! crypto map hryak local-address FastEthernet0/1 crypto map hryak 10 ipsec-isakmp set peer 192.168.200.241 set transform-set hryak set pfs group2 match address 187 qos pre-classify
interface Tunnel0 description Hohryak-P100-GRE bandwidth 10240 ip address 192.168.200.226 255.255.255.252 ip mtu 1440 ip route-cache policy no ip route-cache cef ip route-cache flow no ip mroute-cache qos pre-classify tunnel source FastEthernet0/1 tunnel destination 192.168.200.241 tunnel flow egress-records
This configuration doesn't work- ping work, but only small ping, packets larger than 100 can't reach another router over ipsec.
If I add compression to transform set crypto ipsec transform-set hryak ah-sha-hmac esp-aes 256 comp-lzs
than all is OK except of performance- I get just about 10Mbit throughput and 100% cpu load- with IP Input.
I guess that compression is done on CPU. I don't need compression anyway :-)
btw, all is OK with physical channel- if I remove crypto I get about
50Mbit throughput.
Could you tell me what is wrong? How can I get ipsec working without compression? May be this is IOS problem (I use 12.4.17a )?
Hello!
I see following on one router:
*Nov 26 09:50:27.134 SAMT: %CRYPTO-4-RECVD_PKT_MSG_LEN_ERR: decapsulate: packet has bad bad pad length for packet: decrypt error? length destadr=1.38.2.161, prot=50, len=8 *Nov 26 09:50:27.134 SAMT: %CRYPTO-4-RECVD_PKT_MAC_ERR: decrypt: mac verify failed for connection id=4
What does it mean?
Hi, there
You could try reducing the MTU on the tunnel interface to 1360.
Also, where is the crypto map applied? I don't see it applied either to the physical interface or the tunnel interface here.
It doesn't help :-( p100-cr2801-1#ping 192.168.200.226
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.200.226, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max =3D 4/4/4 ms p100-cr2801-1#ping Protocol [ip]: Target IP address: 192.168.200.226 Repeat count [5]: Datagram size [100]: 200 Timeout in seconds [2]: Extended commands [n]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 5, 200-byte ICMP Echos to 192.168.200.226, timeout is 2 seconds: =2E.... Success rate is 0 percent (0/5)
Now I'm trying to use crypto tunnel with the same result :-(
interface Tunnel0 ip address 192.168.200.225 255.255.255.252 ip mtu 1360 no ip route-cache cef no ip route-cache ip ospf cost 2 ip ospf mtu-ignore tunnel source 192.168.200.241 tunnel destination 192.168.200.242 tunnel mode ipsec ipv4 tunnel protection ipsec profile hryak-p end
the same config on another end.
and
p100-cr2801-1#sh crypto sess Crypto session current status
Interface: Tunnel0 Session status: UP-ACTIVE Peer: 192.168.200.242 port 500 IKE SA: local 192.168.200.241/500 remote 192.168.200.242/500 Active IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0 Active SAs: 2, origin: crypto map
I can't understand why it works OK with compression, and all is OK without encryption...
On 28 =D0=BD=D0=BE=D1=8F=D0=B1, 21:46, Dmitry Melekhov wro= te:
e:
btw, it is very strange, but if I set ip mtu less then 120 on far end (not otherwise) than large (1500) pings pass. looks like something is wrong with ethernet channel. but I can't understand what- unencrypted traffic has no problems on this channel...
OK. Looks like this is cisco IOS bug. I replaced 2801 with 2811 on one side and get channel worked for some time. Than 2811 hangs :-) , so I replaced ios in 2801 to older one (12.4.13d afair). Now channel works for more than hours. Only "problem" is many messages in 2811 log: Nov 30 08:55:51.188 SAMT: %CRYPTO-4-IKMP_NO_SA: IKE message from
192.168.200.241 has no SA and is not an initialization offer Nov 30 08:57:40.754 SAMT: %CRYPTO-4-IKMP_NO_SA: IKE message from 192.168.200.241 has no SA and is not an initialization offer Nov 30 08:59:40.776 SAMT: %CRYPTO-4-IKMP_NO_SA: IKE message from 192.168.200.241 has no SA and is not an initialization offer
I'm shure this is bug too...
