Cbus and X10
Aug 04, 2006 3 Replies
Jump to replies (3)
Hi all,
I have a question that I hope someone can answer here in Australia we dont get the same x10 switches that are availale in the US, I like the Clipsal C-Bus switches and these switches appear to be momentary action switches anyways.
I was wondering if it is possible to use these switches with an X10 setup and as I slowly update my light switchs then I can move to c-bus as a phased migration?
Is this possible ?
Thanks Imran
Hi Imran
No its not possible to use CBUS switches to directly control x10 kit...
Frank
Hi
I probably should have expanded my comments as you have to state that a third party controller could send x10 commands in response to CBUS commands.
This would quite easy using xPL which has both a x10 plugin and CBUS Plugin ..but means that a pc needs to be used......
Frank
