Having Problems connecting through VPN
Mar 28, 2006 2 Replies
the following is the vpn client log:
Cisco Systems VPN Client Version 4.7.00.0533 Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2 Config file directory: C:\\Program Files\\Cisco Systems\\VPN Client
1 16:22:55.328 03/28/06 Sev=Warning/3 IKE/0xE3000056 The received HASH payload cannot be verified
2 16:22:55.328 03/28/06 Sev=Warning/2 IKE/0xE300007D Hash verification failed... may be configured with invalid group password.
3 16:22:55.328 03/28/06 Sev=Warning/2 IKE/0xE3000099 Failed to authenticate peer (Navigator:904)
4 16:22:55.328 03/28/06 Sev=Warning/2 IKE/0xE30000A5 Unexpected SW error occurred while processing Aggressive Mode negotiator:(Navigator:2202)
You did not give us much information to go on, but what you did post suggests...
That you are using the wrong group password
The group name that you need to use is the name you gave the 'vpngroup'. The group password that you need to use is in 'password' clause of your 'vpngroup' configuration.
If that doesn't help, we will need more information, such as the platform you are connecting to, the software version for that platform, and all information from the configuration that is related to VPNs (make sure you edit out any password information.)
