Flow Control in Trunk
Aug 08, 2006 3 Replies
Jump to replies (3)
As we all know, the function of flow control can be set on a single port. but i'm wondering, can it be applied to a trunk? i feel the answer should be no, however, if we consider trunk as a logic link, the result will be different, won't it? anyhow, confused... who can give me a clear explanation? thx...
you can set flow control on trunk-capable ports, if this is what you are asking?
_cjk
my point is that if i set a trunk group, will flow control take effect on its trunk members?
