Extended VLAN(s) not allowed in current VTP mode
Feb 07, 2007 3 Replies
Most relevant reply
Doan
Yes, but you will lose if the extended-vlans if the switch reboots.
Extended VLAN(s) not allowed in current VTP mode open original image
goal here is to add a couple of extended vlans (in 2000-3000) range to a client switch. these vlans should not be broadcast across the domain. is it possible to add to a client switch?
I've actually tried adding to the server switch as well and get the same error.
sh run .... spanning-tree extend system-id .... sh vtp stat ..... VTP Version : 2 Configuration Revision : 18 Maximum VLANs supported locally : 255 Number of existing VLANs : 12 VTP Operating Mode : Client (also tried the server switch for this domain) VTP Domain Name : * VTP Pruning Mode : Disabled VTP V2 Mode : Enabled VTP Traps Generation : Disabled MD5 digest : 0xE2 0xCF 0x5B 0x2B 0x3A 0xD5 0x3E
0x2D Configuration last modified by 172.22.0.211 at 8-21-93 01:15:32 .... sfo2-sw-04(config)#vlan 2542 sfo2-sw-04(config-vlan)#name * sfo2-sw-04(config-vlan)#end % Failed to create VLANs 2542 Extended VLAN(s) not allowed in current VTP mode. %Failed to commit extended VLAN(s) changes.
Have you tried doing it in transparent mode?
Doan
I want this switch to be in client mode in general to pick up other vlan changes in the domain. can i put it in transparent temporarily to add these vlans then move it back to client without those vlans going away?
Doan
