Not seeing all VLANS
Oct 12, 2007 1 Replies
Hi I have several switches, a 3750 Catalyst, a 3650 and 2 2960's The 2 2960's are not seeing all the VLANs and I can't work out why All switches are using VLAN1 and all are in the same subnet
10.200.200.0
Here is the config bits
3750 sh vtp status VTP Version : 2 Configuration Revision : 2 Maximum VLANs supported locally : 1005 Number of existing VLANs : 10 VTP Operating Mode : Server VTP Domain Name : AFF VTP Pruning Mode : Enabled VTP V2 Mode : Disabled VTP Traps Generation : Disabled MD5 digest : 0x28 0xDE 0x37 0xB2 0xF6 0xE9 0x36
0x7A Configuration last modified by 10.200.200.1 at 11-7-06 04:43:32 Local updater ID is 10.200.200.1 on interface Vl1 (lowest numbered VLAN interface found)
sh int trunk Port Mode Encapsulation Status Native vlan Gi1/0/2 on 802.1q trunking 1 Gi2/0/2 auto n-802.1q trunking 1 Gi2/0/4 on 802.1q trunking 1 Gi3/0/1 on 802.1q trunking 1
Port Vlans allowed on trunk Gi1/0/2 1-4094 Gi2/0/2 1-4094 Gi2/0/4 1-4094 Gi3/0/1 1-4094
Port Vlans allowed and active in management domain Gi1/0/2 1,5,11,26,100-101 Gi2/0/2 1,5,11,26,100-101 Gi2/0/4 1,5,11,26,100-101 Gi3/0/1 1,5,11,26,100-101
Port Vlans in spanning tree forwarding state and not pruned Gi1/0/2 1,5,11,26,100-101 Gi2/0/2 1,5,11,26,100-101 Gi2/0/4 1,26 Gi3/0/1 1,5,11,26,100-101
sh run int g3/0/1 interface GigabitEthernet3/0/1 description Trunk to WA-3560-01 Port Gi0/2 via Patch 214 switchport trunk encapsulation dot1q switchport mode trunk no ip address speed 1000 mdix auto spanning-tree portfast end
sh run int g1/0/2 interface GigabitEthernet1/0/2 description Link to Cisco 2960-2 Port Gi0/1 switchport trunk encapsulation dot1q switchport mode trunk no ip address no mdix auto end
sh run int g2/0/4 interface GigabitEthernet2/0/4 description Link to Cisco 2960-1 Port Gi0/1 switchport trunk encapsulation dot1q switchport mode trunk no ip address no mdix auto spanning-tree portfast end
3560 sh vtp status VTP Version : 2 Configuration Revision : 0 Maximum VLANs supported locally : 1005 Number of existing VLANs : 7 VTP Operating Mode : Client VTP Domain Name : AFF VTP Pruning Mode : Disabled VTP V2 Mode : Disabled VTP Traps Generation : Disabled MD5 digest : 0x9C 0xBE 0x0D 0x2E 0x18 0x97 0xEA
0x51 Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
#sh int trunk Port Mode Encapsulation Status Native vlan Gi0/2 desirable n-802.1q trunking 1 Port Vlans allowed on trunk Gi0/2 1-4094 Port Vlans allowed and active in management domain Gi0/2 1,26,100 Port Vlans in spanning tree forwarding state and not pruned Gi0/2 1,26,100
sh vlan bri VLAN Name Status Ports
1 default active Gi0/25, Gi0/26, Gi0/27, Gi0/28
26 USERVLAN active Gi0/1, Gi0/3, Gi0/4, Gi0/5, Gi0/6, Gi0/7, Gi0/8, Gi0/9, Gi0/10, Gi0/11, Gi0/12 Gi0/13, Gi0/14, Gi0/15, Gi0/16, Gi0/17, Gi0/18, Gi0/19, Gi0/20, Gi0/21, Gi0/22 Gi0/23, Gi0/24
100 SERVERVLAN active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
One of the 2960's sh vtp status VTP Version : 2 Configuration Revision : 0 Maximum VLANs supported locally : 255 Number of existing VLANs : 6 VTP Operating Mode : Client VTP Domain Name : AFF VTP Pruning Mode : Disabled VTP V2 Mode : Disabled VTP Traps Generation : Disabled MD5 digest : 0x05 0x61 0xE0 0x2C 0xEB 0x96 0xF4
0x47 Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
26 USERVLAN active Fa0/1, Fa0/2, Fa0/3, Fa0/4 Fa0/5, Fa0/6, Fa0/7, Fa0/8 Fa0/9, Fa0/10, Fa0/11, Fa0/12 Fa0/13, Fa0/14, Fa0/15, Fa0/16 Fa0/17, Fa0/18, Fa0/20, Fa0/21 Fa0/22, Fa0/23, Fa0/24, Fa0/25 Fa0/26, Fa0/27, Fa0/28, Fa0/29 Fa0/30, Fa0/31, Fa0/32, Fa0/33 Fa0/34, Fa0/35, Fa0/36, Fa0/37 Fa0/38, Fa0/39, Fa0/40, Fa0/42 Fa0/43, Fa0/44, Fa0/45, Fa0/46 Fa0/47, Fa0/48
sh int trunk Port Mode Encapsulation Status Native vlan Gi0/1 on 802.1q trunking 1 Port Vlans allowed on trunk Gi0/1 1-4094 Port Vlans allowed and active in management domain Gi0/1 1,26 Port Vlans in spanning tree forwarding state and not pruned Gi0/1 1,26
Port Fa0/19 has switchport access vlan 100 set on it but I am not seeing VLAN100 in the list
If anyone could offer any ideas it would bemost appreciated
Scott
Okay, so first part, is your VTP isn't working. Not sure if you are thinking it should..
So, they aren't seeing any pushdowns of VTP data, so they won't learn of VLANs automatically. The displays show that they should be doing VTP, but something isn't working there, since the config rev's are 0 on the clients and not matching the config rev on the VTP server.
With the switch in VTP client mode, it won't automake the VLAN into the list when applied on a switch port.
Either figure out what in VTP isn't working, or manually create all VLANs on each switch and ignore VTP altogether with the 'vlan xx' config item.
