Etherchannel - which mode should I use?
Nov 28, 2009 1 Replies
Thrill5
Six of one, half-dozen of the other. Both work just fine, the only real difference is that LACP is an IEEE standard and PAgP is Cisco proprietary.
Hi all,
I am wondering which etherchannel mode should I use and why? From what I can see Etherchannel can be used across Cisco 3750 stacks as long as the stack runs on IOS 12.2(25)SE or newer and one uses LACP, but if I am reading this correctly below two should work:
channel-group [#] mode on (disables PAgP, enables LACP) and channel-group [#] mode active (use LACP in an active mode, it will start to send LACP packets)
If so, which one should I use and what are the pros and cos of both? Could someone clarify this for me?
Thanks a lot.
