Extending LAN question
Sep 08, 2005 2 Replies
Gurus I have a subnet that i would like to extend using two cisco 2514 routers but i would like to maintain the extended segment with the same subnet address so as to facilitate the move of equipmernt from one location to another. Here is what I would like to do:
10.214.100.X ---2514---G703-----E1----G703---2514---10.214.100.X LAN EXT. FFFFFF00 FFFFFF00 Local LAN Router MegaStream Router Extended LAN
Can i do this or do I have to set up a separate subnet? Howdo i configure my 2514's to pass traffic straight thru ?
Many thanks dean
Yes you can. You'll need to setup static NAT if you want the migrated and the non-migrated hosts to talk to one another during the transition stage.
Cant i set up the 2514 and transparent bridges with no ip addresses so that they carry out layer 2 routing functions.
Will this work:
10.214.100.X
------2514-----g703-----E1-----g703----2514----10.214.100.X no ip no ip
what i need is a config file that shows me how to set this up#
many thanks dean
