Trunk for a workstation
Jan 10, 2012 4 Replies
Jump to replies (4)
Hi, all,
A simple question:
  1. A layer 2 Catalyst switch with different VLANs configured.
  2. A trunk configured in a switch port
  3. A windows workstation with only one NIC
  4. The workstation is connected to this trunk port.
Questions:
  1. If different IP addresses to the workstation ( one NIC only )
  2. can this workstation work ( this workstation connected to a switch trunk port )?
  3. can this workstation go to these different IP subnets ?
  4. Can these IP subnets communicate with each other ( via the workstation as router ) ?
The wise snipped-for-privacy@yahoo.com.hk enlightened me with:
Is that a question?
yes, if the operating system/driver supports this and you configure it correctly
Mark
Hi, Thanks for the answers.
Want to know more:
  1. in Q4, if workstation is as router between these subnets by default ?
  2. How can I configure the workstation for only the workstation can communicate with these individual subnets, but other hosts in these subnets can not communicate each other ?
Thanks a lot
snipped-for-privacy@yahoo.com.hk schrieb:
You should understand the difference between a physical NIC and logical NICs for each configured 802.1q VLAN first.
If the O/S is forwarding packets between different logical NICs/interfaces depends. By default Windows does NOT route.
Access-lists.
Hi, For the answer "Access-list"; you mean ACL in Switch or workstation ?
  1. Switches are configured in Layer 2 and no inter-VLAN route in the whole network environment, what ACL is applied ? if ACL in windows platform, May I know how to create a ACL in windows since I never do a ACL in window ?
  1. What is the checklist in windows system/driver in order to enable the NIC drive supports
2.1 "4. Can these IP subnets communicate with each other ( via the workstation as router ) ? yes, if the operating system/driver supports this and you configure it correctly "
Thanks for the help
