wildcards ?
Sep 05, 2005 2 Replies
Barry Margolin
permit 10.0.1.1 0.255.0.0 permit 10.0.1.2 0.255.0.1 permit 10.0.1.4 0.255.0.1 permit 192.168.0.61 0.0.255.0 permit 192.168.0.62 0.0.255.1 permit 192.168.0.64 0.0.255.1
I have this task:
limit access via ACL to the following:
allow only hosts on 10.xxx.1.1 to .5 and 192.168.xxx.61 to .65 xxx = what ever network in this octet
how can this be done with wildcards or any other smarter way ?
I have tried fx 0.255.0.255 but this doesnt work. looks like the wildcards must be consistant ...
8(
regards
Martin
Hi Barry and thank you for your reply.
Exactly this I have allready tried, but it doesnt work. Maybe I should have stated that this is for use with Cisco ACS for windows and the formerly know as feature, downloadable PIX ACL, now called USer downloadable ACL, and it is destined for a VPN3030 ver 4.7.
I get the message, that the vpn will not install the mask 0.255.0.1 or any other mask that are not consistent of a row of "1" bits. I am not sure if this is related to the VPN3030 or ingeneral also for IOS device.
If I type in the ACL on a IOS router it will "eat" the lines.
Any other ideas ?
regards, Martin
