do 2517/18/19 use different memory than other 2500s?
Mar 11, 2005 1 Replies
BradReeseCom
You may wish to investigate Cisco Router Memory Tables: well as the Refurbished Cisco Product Guide: Page 48 PDF, Page 46 Document Cisco 2500 Series Brad Reese Cisco Resource Center United Kingdom: 44-20-70784294 U=2ES. Toll Free: 877-549-2680 International: 828-277-7272 Fax…
do 2517/18/19 use different memory than other 2500s? open original image
I couldn't console into my 2519 from ebay, so I thought I'd see if the ram and flash were any good, so I put them in a 2502. First it reported bad ram, but still hung on flash with my good ram back in.
I know the 2519 boots up, because he lights blinked for self test, then several ports flash looking for a connection, and I got a password prompt on the aux port.
I found posts saying the console port wiring is different, but I misplaced my rg45 cable crimper so instead of making a cable I tried the other solution, setting jumpers to switch the con to the aux port, but that did not work either.
Lastly, here is what I got when I put the ram and rom in a known good
2502. With ram and flash or just flash in my 2502p, all hung, some not even putting out the copywrite message):
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE Copyright (c) 1986-1995 by cisco Systems 2500 processor with 4096 Kbytes of main memory
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE Copyright (c) 1986-1995 by cisco Systems Bad memory - wrote zero, read 0x00000600 at location 0x000000EC
Hmmmm, since the 2518 only has one flash slot, maybe it can take a 16m flash, and this is one, and that causes problems in a 2500? Maybe I should try just the ram in the 2502 (although 4M or ram has no value to me).
as well as the Refurbished Cisco Product Guide:
Cisco 2500 Series
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center United Kingdom: 44-20-70784294 U=2ES. Toll Free: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558=20 Website:
