Differences between 2950 adn 2900
Feb 08, 2005 7 Replies
Jump to replies (7)
Differences between 2950 adn 2900 open original image
Can you please tell me what significant differences there are between the Catalyst 2900 and the 2950 series of switches?
Fred
About 50.
Well, I know that the 2950 doesn't support ISL. Are there any other differences that are significant?
Fred
Folks,
Let's try this one again.
Someone suggested that I use a Catalyst 2924-XL rather than a
2950. I was told that I would notice no differences using it to do Cisco lab assignments.
Not being familiar with the 2924 series, I'd like some other opinions.
Would you go with a 2924 for this purpose? Why would you? Which of you would not go with this? Why would you not?
Thanks,
Fred
Mate, it's all in the feature list. There's a significant amount of differences between these two switches, and no-one is very likely to explain all the differences when they're freely available on CCO.
The CCIE course now recommends 3750's I believe. 2924's just aren't going to cut it.
But I'm not yet taking CCIE. I'm just finishing up CCNA. The
2950 will do fine for that. What I want to know is how different the 2924-XL would be from the 2950. Also, what is the significance of the XL suffix?
Regards,
Fred
Cool, well you have already been given the means to the answers.
