dialer problem
Jan 03, 2007 3 Replies
Jump to replies (3)
dialer problem open original image
I have remote access solution and I am using dialers. As I understand there is limit of number of dilaer interfaces and I am getting close to that limit. What steps should I take? Replace it with waht tecnology? Or can I overcome this limit somehow?
thanks!
~ I have remote access solution and I am using dialers. As I understand there ~ is limit of number of dilaer interfaces and I am getting close to that ~ limit. What steps should I take? Replace it with waht tecnology? Or can I ~ overcome this limit somehow? ~ ~ thanks!
Virtual profiles.
thx, do you have some kind of example or something?
~ On Wed, 03 Jan 2007 11:16:32 -0700, Aaron Leonard wrote: ~ ~ > On Wed, 3 Jan 2007 12:54:00 +0100, Drx wrote: ~ > ~ > ~ I have remote access solution and I am using dialers. As I understand there ~ > ~ is limit of number of dilaer interfaces and I am getting close to that ~ > ~ limit. What steps should I take? Replace it with waht tecnology? Or can I ~ > ~ overcome this limit somehow? ~ > ~ ~ > ~ thanks! ~ > ~ > Virtual profiles. ~ ~ thx, do you have some kind of example or something?
Cisco IOS Dial Technologies Configuration Guide, Release 12.4
